Do you have any mods at all?Nissan2367 wrote:Mine does the same thing... on stock timing. Its normal from what i have read on RB's
You need to be at 15° btdcdatsunmotorsports wrote:The timing is at 10*.
^^ Exactly what I was getting at ^^Nissan2367 wrote:I miss understood mine do it when i let up off the gas after wot. Mods:Greddy Type RZ BOV (not recirculated)
Nissan2367 wrote:wow i need to set my timing! Mine is dead center with no timing ether way!
Yeah like I need the extra HP... Its a RB25DET in a Datsun 260z and I already have mad traction issues with drag radials...S14-NEO wrote:hehe only 10 degrees of timing, man is he in for a treat when he corrects his timing to 15 degrees...yeah FREE HP....woot
Make sure your CAS is in the middle. That will be ~15 on a stock motor.datsunmotorsports wrote:Initially I was able to set the timing on my motor with a ETHOS scanner, but when I tried to set it at 15* with a Modus Scanner the computer just self corrected my timing adjustments and would not show me the actual timing just the corrected timing.
im sorry but i have to say that is one awesome a** response...WELL DONE!!!l0nestar wrote:
Fixed my timing. Tossed a random wire I had around for the old L28 on the #1 coil and plug and timed it correctly. There is a notable difference in power. Its not huge but you do notice the difference. The powerband is smoother with the correct timing.S14-NEO wrote:hehe only 10 degrees of timing, man is he in for a treat when he corrects his timing to 15 degrees...yeah FREE HP....woot
How far off is it from the middle? A lot of timing guns have problems reading the nissan DI.meet07 wrote:my cas isnt set in the middle and dead on base timing. I as well shoot about 2-3 fireballs a day. I see most of them in the morning. Other times I hear it. I have a safc to correct the maf signal with the atmospheric bov.
you are using an atmospheric bovmeet07 wrote:my cas isnt set in the middle and dead on base timing. I as well shoot about 2-3 fireballs a day. I see most of them in the morning. Other times I hear it. I have a safc to correct the maf signal with the atmospheric bov.
