I finally got my hands on an ECU so its time to get back to the swap. i cut off the KA F3 plug's wires and spliced all the Wires from the RB 'F3' plug that i could figure out. I need help with some leftovers. I listed all the wires i have lefton the KA plug, I'll try to get a list of the ones left over on the RB plug by tomorrow or friday. If anybody can help i'd really appreciate it.
1)These are the wires that i don't have connected, if anybody knows where they connect to on the S1 RB25DET please let me know. the consult wires, from what i've read, have nothing to do with just getting the car running so i'm not too concerned about those but the other ones i wanted to know where they connect to.
KA F3 wires not connected
3 Blue/Red -------Rear Defogger10 Black/yellow -------IACV-Air Regulator15 Purple/white -------Powersteering<<16 yellow/black -------AC switch>>20 Red -------Data link for GST(KLINE)22 Green -------CONSULT(SCITX)23 Green/white -------CONSULT(SCICL)25 Orange/Blue -------Cooling Fan(RFRH)33 Yellow/Blue -------5th Position Switch(5SW)<<37 Orange/Black -------Recirculation Relay>>38 Green/Black -------CONSULT(SCIRX)41 Blue/Green -------cooling fan(RFRL)43 Black/Pink -------Triple Pressure Switch(ACRLY)44 Blue/Red -------IACV-FICD solenoid from AC relay45 Orange/Black -------IACV-FICD solenoid(PDSW)<<46 Orange/Blue -------AC Thermo control Amp>>
2)on the KA F3 plug, pin 18(Brown), Power from IGN switch, does that connect tothe thick Red wire on one of the RB relays, i think its the ignition relay.
3)On RB F3, the Black/Blue wire from the temp sensor for the ecu, where does that go. one wire goes to the ecu and the other one went to the plug, so where do i connect it to on the KA F3 plug.
4)on RB F3, light blue or Cyan wire that comes from the engine in the area wherethe knock sensors and oil pressure wires come from, what is it for and where does it go?
Any help will be greatly appreciated. i really need to get this thing on the road
