tokendog »
https://forums.nicoclub.com/tokendog-u83450.html
Mon Aug 11, 2008 6:06 am
Work/school/life is finally allowing me to finish my car and as I near completion, I find myself running in to a few roadblocks.
I had to borrow these images from Positron's post and hope he's ok with that, if not, I'll take them down. I did not have a data transfer cable available and needed to find out the answers to this stuff...so thanks Positron.
On the piece that holds the Coolant Temp Sensor and connects to the head, I could not find a gasket for it. In this pic, you can see there is a gasket, but I have been unable to find one online. Can I use red RTV for this or does it require a gasket?
Here's the pic...Referring to the area a little to the right of the wrench.
Also, I ordered new studs for my turbo where it meets with the 02 housing/downpipe. I ordered 5 new studs and locking nuts from frsport. My question is how do you install studs properly? I've never had to do it except for on my head. Hand tighten, then torque to spec, and the torque should fit it snuggly or is there a better way to ensure a good fit?
Thanks!!
Modified by tokendog at 9:51 AM 8/11/2008
