finishing the auto to man conversion
1grns14
OK, im pretty much done with the 95 240sx auto to manual conversion. The car starts, but when it starts is goes to 3.5-4k for the rpms, any ideas as many as you have would be good. and the final thing before the car is done, my clutch pedal doesnt have pressure or something, because if you press it it just snaps to the floor and wont come back up by its self, you have to pull it back up. it has fluid. Do you have any ideas why this is happening. Thanks for all your help. Pete. you can write back at [email protected]
kim
Car: 90 240sx, 97 M3
About the clutch problem you where discribing sounds like you didn't bleed the clutch properly. I usually get this feeling when I release the bleeder valve or there is air in the system
NISTECH
sounds like your throttle is stuck open. make sure your cables at the throttle body are slack at idle. one of them might be pulling the throttle plate open.
You need to blled the hell out of your clutch hydrolic system you have a tremendous amount of air in the system.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
do s14's have the same type of damper block as s13's do? if so... get rid of the sucker :)
