cdlong »
https://forums.nicoclub.com/cdlong-u11619.html
Wed Jun 21, 2006 7:24 pm
i'm no intake manifold designer but that plenum looks too small. it's supposed to be a reservoir of air, not an extension of the runners. i think that one will make cylinder #1 run lean and #6 run rich. it will also act like really long runners, good low end torque but terrible top end.
you could cut the top section off and add an inch wide strip of aluminum around the horns and weld the cover back on. that would give you room to move the TB out away from the water neck.
if you don't do that, i would rework the water neck so the TB has a straight shot into the plenum.
do you have a picture of the whole thing? that will give us a better idea of the size and taper at the back end.
