hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Fri Feb 25, 2005 5:29 am
when i removed my egr, i removed the freaking thing and covered the intake manifold inlet for egr with some sheet metal, some bolts and silicon. if it doesn't boost past 1 psi then you most likely have a leak, and you're probably overworking your turbo like crazy because it's just spooling without bound to make only 1 psi and the wastegate never opens. stop boosting until you fix the leak, if that is in fact the problem.
here's what i did specifically when i installed my turbo:the stock vacuum setup sucks. there are a lot of things on the car that you can eliminate if you want to. when i installed my turbo i took off the intake manifold completely and worked with all of this outside of the car because i had to close off my aicv because it was crappy and i eliminated egr because i didn't want it anymore. with this comes the joy of ripping off all of the old vacuum lines and then making your own vacuum setup, with new silicon lines, if wanted.
anyway so i removed the egr control deal that ius mounted on the back of the valve cover. the map sensor is also back there, and i removed that also because the map sensor on our cars doesn't actually control anything.. it's just a check valve kind of thing, according to nissan. so i took that off and removed the crap in back of the valve cover (there's a metal vacuum line routing contraption). pretty much i then started from scratch and used the vacuum ports on the manifold to rig up vacuum lines to my bov, wastegate, fmu, and a few other things. i took off the vacuum for the charcoal canister in the front and blocked that off. the vacuum control valve things for crank case ventilation (i think that's what it is... )my terminology sucks right now, but i'm in a hurry... i have to go write up a lab report.
my car runs great, no leaks and makes perfect vacuum and boost. i'll try to get some pictures of what i am talking about... what i did was simple, and it works great.
