Finished turbo install with PROBLEMS!!!
elpiar
Car: 1992 KA-T
S13 KA24DE w/ t3/t04e. My ECU basemap tune is fine before I got the turbo in, so pretty sure it's not the tune
Here are my symptoms:- Will not build boost at all (only goes up to 0 psi)- Turbo does not sound spooling up (maybe boost leak?)- Very rich idle- Bogs down and very bad hesitation under partial throttle- No CEL light
I haven't run my consult and see what some voltages.
Help?
virus77
Car: 95 S14, 71 240z, 97 e320
internal or external gate? could be your gate is wide open if you are internal, not likely if you are external.
elpiar
Car: 1992 KA-T
External
BTW i forgot to mention first time i start it, the idle is very high, like 2k or sth. And then after it got too rich I think it fouled the plugs and then the idle start dropping and get rough.
Florida240sx
Give information about your kit. Injectors, turbo brand and size, wastegate brand and size, injectors mafs tuning device etc.
frsh13
Car: 1991 240sx coupe
sounds like your wastegate is stuck open (assuming your using external gate)
As for the richness, what are you using for tuning?
Craving4Boost
Car: 91 240sx fastback
what maf are you running and what decribe your tune more...
neverlift
I'm gonna go out on a limb here and say he has a rom tune, wastegate wide open ftl
eazye2000
Car: S13 KA-DET
Did you hook the 'In' and 'Out' of the turbo up correctly? J/K~! Are you just revving the motor while it's parked? It's kinda hard to build boost at a stand still. You have to drive the car. Have you tried driving it yet?
neverlift
lol I can hardly make boost in N this kid asked me to rev my car then later tried to say it doesnt have a turbo cause he didnt hear it I might make a pound in park. and thats on me tiny turbo t25
elpiar
Car: 1992 KA-T
My setup:
- Built KA, 9:1 CP pistons, eagle rods- Z32 MAF- Deatschwerks 555cc- Base tune from Calum (using calum basic chipped ECU, non-realtime)- t3/t04e 50 trim .48 a/r- JGS wastegate- DSM bov, bypass setup not blow off
I drove the car and it doesn't build boost.
If wastegate is open, it should have no problem between idle up to 0 psi, right? But I have very bad hesitation, very rough idle and very rich idle.
The tuning was perfect the day before I am boosted though.
I'm doing a boost leak today, we'll see.
more suggestions are welcome, I still need to learn a lot
Modified by elpiar at 10:13 AM 11/17/2007
WDRacing
Easy, ic pipe popped off.
neverlift
WDRacing wrote:Easy, ic pipe popped off.
I have one that pops off daily almost! well it has been cause I went up to 8ish psi.
elpiar
Car: 1992 KA-T
well, i didn't see one pop off, but will definitely check for leak.
eazye2000
Car: S13 KA-DET
Hairspray = Intercooler Pipe sealant
...may not 'seal' it per say, but will keep it from sliding/popping off. T-Bolt clamps help too.
Florida240sx
IC hole?
elpiar
Car: 1992 KA-T
you're right. One of the coupler behind the bumper (hence was invisible until i remove the bumper) popped off.
I was working in my friends garage and forgot to bring my keys so I'll start her up tomorrow and hopefully it's fixed.
thanks for all the help guys.
eazye2000
Car: S13 KA-DET
Use hairspray!
elpiar
Car: 1992 KA-T
The car now runs, and I can build boost up to like 3-4 psi, but something is still wrong, I cannot rev past 3.5k rpm. after building the boost. I can hear the WG dump tube opens, but it seems too early.
Looks like i still have a leak.
WDRacing
Have the wastegate and boost gauge referenced from the same spot. What exactly happens at 3500rpm?
WD
spooled240
Car: kouki s14
this may sound stupid but check and see if the ic pipe didn't blow off again or if there is a slight leak where unmetered air that didn't pass through the mafs can get in or out.
i couldn't rev past 1500rpm's after one of my pipes blew off so fixed that mofo with hair spray and doubled up on clamps, SHAZAM!! done deal..
elpiar
Car: 1992 KA-T
YEAH!!! I just found one more leak. Now I'm running good and spoolinnnnn
THanks everyone for the help!
s13_maniacs
Car: 240sx Coupe
+1
Florida240sx
I liked my big t3/t4 I could pop a pipe off, and if I eased into the throttle I could still boost some, frantes it was the joint coupler of cold pipe to pipe to ic so it was seperates but still facing each other. Started becoming a habit every 20minutes of spirited driving.
spooled240
Car: kouki s14
haha, when i first took my car out for a spin after the turbo setup the ic pipe blew off at 12psi and scared the sh*t out of me lol as you may know, the first drive on boost is all ears and gauge monitering so the big "pop" noise made me jump out of my pants..then it was 1500rpms in 5th at 10 mph in limp mode back to base..
