Finished swap but car won't start
239s13
I have an 89 240sx with a CA18DET swap. The wiring has been done exactly like an SR20DET, im getting gas and spark, but it wont start. I am getting fuel to the injectors, they are all spraying, but when the car is cranking they stop spraying. When i connect the red wire from the dropping resister to a 12v source, the car will start, but misfiring. the car is perfectly grounded. Does anyone have any suggestions on what the problem might be?
Modified by 239s13 at 6:36 AM 6/7/2009
Modified by 239s13 at 6:48 AM 6/7/2009
boost_boy
239s13 wrote:I have an 89 240sx with a CA18DET swap. The wiring has been done exactly like an SR20DET, im getting gas and spark, but it wont start. I am getting fuel to the injectors, they are all spraying, but when the car is cranking they stop spraying. When i connect the red wire from the dropping resister to a 12v source, the car will start, but misfiring. the car is perfectly grounded. Does anyone have any suggestions on what the problem might be?
It's almost wired like the SR, but not completely. Bottm line is, it's not wired correctly and it will be very hard to give you solid advice unless we had something to look at. At worst case scenario, you may have to have the harness looked-over by someone who has a better idea of how it works. Sounds to me like your injectors are not getting any power based on the test you say you did.
Dee
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
yep yep, sounds like a wiring issue.
239s13
thanks for the advise ill revise the wiring, im using the ca lower harness and i have and extra plug:is that plug important?
239s13
the friend who did the wiring for me said that he didnt touch the injectors wiring at all
Modified by 239s13 at 6:30 PM 6/7/2009
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
i followed the old heavy throttle wiring guide, but that site is gone and the link lost in the essence of the internet..if anybody can source it, its a good way to check your wiring, as i haven't seen a better one than that EVER. try going over the wiring again with the one on http://www.frsport.com and see if that helps.
239s13
checking the wiring tonite..
Modified by 239s13 at 7:40 PM 6/8/2009
239s13
we checked the wiring tonite with a voltometer and everything looked good,we started the car after cleaning the spark plugs and it is still misfiring(im getting new spark plugs tomorrow anyways), we tried moving the CAS a little bit and the car ran much better without misfiring, we set it back to factory tho, what do you guys suggest i should do if the spark plugs dont fix the misfiring?
sjbsuperman1425
CA18DET
did you use a timing light when adjusting? maybe the timing is just off?
239s13
im gonna rent one today when i go to autozone to get my spark plugs hopefully thats the problem
sjbsuperman1425
CA18DET
yea do that and report back.
btw, i messaged you on myspace.
239s13
got new spark plugs today but, the car still running the same, im checking it with the timming light tomorrow and checking the wiring one more time
239s13
Got another problem now, the car was idleing while was adjusting the cas, i go to turn off the car but the car turned off itself, i cranked it again but the car would act like the battery was disconnected(no lights, no acc, no click, no nothing) i checked the terminals, grounds, fuses and relays but everything looks perfect, im getting 12v everywhere, but the car acts like there was no battery at all, i been trying to fix this since yesterday with no luck, did any of you guys had a problem like this before?
sjbsuperman1425
CA18DET
so you had the CAS all set and everything and it was idleing good? just tryin too narrow things down..
it sounds like it could be something in the ignition switch or around there..do you get 12V to everything when the key is turned to ACC and ON, or just when its off?
239s13
i was adjusting it, i didnt get a chance to set the timming, the car is acting like the if the battery was disconected, i dont get power at all. While i was testing a relay with a 12v wire and a groung wire they accidentally touch each other(just a little bit) and for some reason the power was back on, so im asuming there is a short somewhere but i dont know where yet
sjbsuperman1425
CA18DET
yea, time to start hunting it down..thats the worse thing about wiring, is b/s problems like this..
239s13
i was eating lunch , when i heard a noise in the garage, it was my windshield wipers, they where on!, the batery was dead, i charged it , well somehow i have power now, but the car wont crank, im gonna check the starter wire when i get a chance
sjbsuperman1425
CA18DET
didn't it crank before? the battery could just be junk. go get it tested. what kind of battery are you running?
239s13
the battery is brand new from autozone, i found that when i crank the car the acc relay clicks, ill see whats going on tomorrow morning
239s13
got the car to start today,taking the car to a shop tomorrow morning, they guy knows what he is doing, he will finish the wiring for me.
sjbsuperman1425
CA18DET
why didn't it start? what did you do to solve the issue?
just trying to get info for others that might have the same problem. report back when you get it finished!
239s13
didnt do nothing , i just jumped i wire from the starter to the battery, im taking it to a shop monday so they can finish the wiring(everything) ill let you guys know what was wrong when the car is done.
239s13
Car is running!! the wiring was fine, the injector plugs were old and the harness connectors were streched, they weren't making good contact, now it runs like butter, im just waiting for my BOV, ill post a vid soon
Fleemer
Car: Pulsar Exa, FC3S
had the same problem with my injector wires, was hard to diagnose.
