Now, the car is running and running amazingly. however, im having an issue with my boost gauge and controller, i think. I have the ISIS BCU(boost control unit), bought it because it had a built in TT but ended up not using it. The controller is working, i have it wired to specs on the book. My boost controller is also hooked up correctly by the manual that came with it. I will include some pictures below, if tinypic works right, to show you guys how i have it hooked up. When i am spooling and boosting my BCU is only showing a 0 - 0.9 psi on the screen. On my boost gauge itself, its showing inbtween 5- 10 and bouncing in the middle of the two. I have the line running to the BCU from the fuel pressure regulator and the intake mani as it said to do in the instructions. I have the boost gauge run from my IC piping that i ut a nipple on to run to my boost solenoid. The other side of the boost solenoid is ran to the wg(wastegate). Now, my BCU is set to start boost at 10lbs on low and cap out at 20 lbs on Hi. I am running both low and Hi but getting the same readings on my boost gauge/BCU.
If anyone could help me that would be amazing. Here are the pics, one is a little small but the other you can easily see the marking i put in.
Here is the T where my line goes to my BCU.
Here are the connections for my boost gauge/wg.
Thanks,
Eric
