meminto »
https://forums.nicoclub.com/meminto-u95701.html
Tue Sep 22, 2009 5:17 pm
Fleemer, I dont understand it either, a stock jdm CA head flows 220cfm, with the whole manifold assembly attached it flows 216cfm. This equates to a 4cfm loss..
I have recently finished helping a mate with a rebuild, he has a 2876r .86 turbo. Before the build he mentioned how dissapointed he was with the lagginess of the turbo, the previous dude had built it and removed the butterflies..
We built the motor, and I advised to reinstall the butterflies and make sure they were working correctly, he is now over the moon with the response in the bottom end and his goal will not even come close to outflowing the stock head...
Not that I am ragging on people for not using them, people have there reasons and quite legitamite ones too, I myself don't use them as a result of the 30 odd % increase in my head flow..
If the sole reason for removing them is because of the perception of a flow restriction, that is an internet myth that has been busted and I have posted the flow data on this site in a previous post that provides the evidence..
I am unsure of the value of the phenolic gasket just yet, but I am interested in your data float when you do have some info, I want to see if it does make a significant difference. I was going to use one myself but I decided against it for a number of reasons..
Modified by meminto at 10:54 PM 9/22/2009
