finished my exhaust
jdmser
Car: duh
It's not really anything special, just my take on how to solve the steering shaft issue. The spacers are 1/2" mild steel. I got 60mm studs and bolts to hold them on. The downpipe is a cheap one off ebay with the flange cut off and rewelded in the right position. The converter is a 3" catco. The rest is a 5zigen Border Max 80mmcatback. It's hard to tell how much space is in between the shaft and the o2 housing in the pic, but there's about a 1/4" gap at the nuckle and about half that from the o2 to the steering shaft at the closest point. Is that going to be enough room? http://nissaninfiniticlub.net/...10377
unstable240
Car: OG RB20DET
I only have one question. Why in the hell did you keep/put a cat on there? Why not just run a test pipe???
dekand
Car: 1995 240sx SE
are those gaskets something you can get anywhere or did you make them yourself? i have an exhaust leak around that area and i think thats the reason but i just havent' looked into it yet.
jdmser
Car: duh
I had the gaskets and flanges/spacers cut on a water jet. If you want one of the gaskets email me at [email protected]
unstable=It cost about the same and I'll pass emissions
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I'll have to show you guys a pic of my High flow resnator.
