Finished KA-T pics
daniel240
Car: cars/motocross
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Clean install! What psi are you running it at for now? Get a fmic yet?
Very nice!
daniel240
Car: cars/motocross
running 8psi w/ the XS T3/T04e turbo w/ hacked mafs and 370cc injectors. actually i was running 10psi the other day but that was because my wastegate was leaking. ill run at 8max to be safe. i got a smic mounted below, thats where the pipes are going.
skydragoness
Ah ok. Well, good luck with the system. What's the mileage on your KA anyhow? Did you do any rebuilding before the turbo install?
I don't plan to go KA-T ever, just curious to see what people are doing with theirs.
BomexS13
Car: '89 Nissan 240SX
'00 Toyota Celica
Very nice:)
daniel240
Car: cars/motocross
skydragoness5 wrote:Ah ok. Well, good luck with the system. What's the mileage on your KA anyhow? Did you do any rebuilding before the turbo install?
85k miles, i did no internal work. depending on the fuel management, most stock ka's are good to 12-14psi before internal work needs to be done.
TachyonS14
SHIZER! That looks really good man. I like how you used your CAI pipe for your IC piping :- P
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
you gotta be kidding if you think you can run that PSI for MORE THAN 20K (beyond now) WITHOUT doing anything to the bottom end. You are gonna need a timing chain and valve job in like 10K before you notice. Check your shim clearance buddy. (even now) You are overdue unless your car has been under Nissan dealership care or according detail...
No offense intended, just the truth.
drifter sx
Car: the usual
fantastic job man
marcusx
Any performance numbers yet? How about HP?
im two techno
Car: 98 240sx se no sunroof!
Looks nice Dan!!!!!
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
:ylsuper
