finished KA-T pics
daniel240
Car: cars/motocross
vadem wrote:Can you tell me where you plumbed you oil, and or water lines? This is the only thing i am unsure about, thanks.
Vadem
i only have oil lines, i didnt need water lines. the oil sending line T's off of the oil sending unit on the other side just below the oil filter. for the oil return, i drilled a hole in the oil pan and welded on a 90deg. elbow and used 3/4'' heater hose up to the turbo for the drain line. i got the oil feed line and brackets from mcmaster or (mc-master.com) for $30 shipped. heres the part numbers:
the feed line itself has 2 fittings that are already assembled the 3-AN to 1/8 pipe thread. so realistically when you get it yuoull have 4 fittings
4092k11 1/8 NPT femal to 1/8 BSPT male $3.684468k401 3-AN (its listed as 3/16th i think) ss braided line with brass fittings 14-16$
50785K219 brass female by female by male brass T $ 0.93
1st one is the adapter from BSPT to NPT so you get the correct thread pitch for the oil pressure sensor hole
2nd one is the actual SS braided line with swivel fittings and connected are two 3-An to 1./8 NPT fittings *( what you screw into the turbo and one for the T )
and the last one is a brass T it has one female ( for the fittings on the SS line) and one female for the oil pressure switch and the male screws into teh adapter and into the block/
the oil return stuff i just bought at a auto parts store.
vuse1
clean setup. what is that blue box by your air filter and charge piping?
daniel240
Car: cars/motocross
vuse1 wrote:clean setup. what is that blue box by your air filter and charge piping?
it is the MSD BTM, it was the only spot that it would fit.
superhoss37
i just got my BTM in today and the instructions with it are CRAP. daniel, could you tell me how you hooked yours up??? i can't figure this crazy thing out. i've got a 98 ka24det. thanks
daniel240
Car: cars/motocross
yea i meant to do a write up on that but i havent had time. yea you might as well throw those instructions away. i am going to have my dad write something up because he's the one who figured it out(he's an electrician), because im not sure if i could explain it to you. i know the white wire needs to go inside the distributor. you will have to take it apart. if you have an fsm, use this on how to take it apart and mark everything so you put it all back together right w/ out having to adjust your timing or anything. so ill get back to you on that. just give me an email,at [email protected]
