myRed240 »
https://forums.nicoclub.com/myred240-u4220.html
Wed Jan 17, 2007 1:11 pm
Wow, thanks for all of the input.
Yes, the IACV goes directly to the cold pipe, in the same location as my AEM intake had it.
I do feel as though my bov recirc is the prob, as it dumps straight into the pipe and isn't angled towards the turbo.
I'm going to measure the MAF distance, but I believe it's around 8" away. There really wasn't much room for me to work with for the MAF.
I'm going to lower the plug gaps a little while I'm at it and try to eliminate the bov as the culprit. I'll also triple check for leaks again. There are two suspect spots, but haven't been able to eliminate them 100%.
Can you give me more info on the boost leak tester?
Thanks guys!
