clovers525e »
https://forums.nicoclub.com/clovers525e-u47904.html
Wed Oct 11, 2006 4:57 am
i guess an update is in order. i checked the fuel pump relay after looking for another 30 minutes. this is on a s14 btw, left that out. checked it, and it was find. installed the walbro and its now working fine, i ended up taking it to a shop and they found out there was "some wire pulled loose" that was about all i got out of them but you could see where they had rewrapped the main harness. its running now, but not like it should. i'm getting a tps sensor code and when i pass a certain point on the throttle the afm goes off the lean end. the car pulls but with alot less power then it should, some time the afm light will pop right up and the power comes back, it usully does it when i pass like 4,200 rpms or at very little throttle. i checked the resistance between connector 3 and 2? the very top wire and the second from the top, it read between .45 to 4.25 something close to that. any easy way to check this?what wire is a signal wire?
p.s. it malfunctions most when driving. or is noticable when driving.
