I dont see how that is easy.youngun21a wrote:I think the easy is to remove the fuel rail and have someone crank the engine,and see witch one is not fireing.
Easy is to start the car, and unplug the plug wire one by one until you find one that doesnt make a difference in idle when unplugged.
Not to be a smartass, but if you know one is "out" then you should obviously know how to find a bad one..afterall you already figured one is bad so you already know how to find a bad injector. Yes? Or am I missing something?nisssan-drive wrote:I no one of my injectors is out but I am just not sure which one. Does any one no how i can find my bad injector?
Well, i said spark plug cable, but i guess you could unplug the injector but it takes more work because of the annoying clip.nisssan-drive wrote:Yeah i definitely don't want to take my fuel rail off Im already tired of shoving my head into the manifold from replacing the knock sensor. I thought of turning my car on and just unplugging the injectors like selimited said ,but I was scared that could maybe mess something up. Guess it works pretty good thanks for the help looks like thats what ill be doing to find my pos injector.
Oh espresso I can't see to find the point of your post. It seems you have figured every thing out, and that your definitely missing something so?????
Try using PB Blaster and this:nisssan-drive wrote:Yeah I guess I just have the word injector stuck in my mind from dealing with them all day. Yeah any ways I did it that way and found it was cylinder #4. Ha do to frustration and a very bad ****ing headache I did not get to replace my injector.One of the damn screws melted like butter in a instant when trying to to unscrew it .
