themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Mon Dec 11, 2006 9:59 pm
I never fired up the car, just physically fit the motor. No inspection shop would even entertain the idea of sneaking it through
A couple of important points to consider.
Again I did this on a RHD S13 Silvia. I am willing to bet Floats good nut you will have interferance with the steering shaft on a LHD 240SX, be ready to deal with that (read, possible custom manifold)
I encountered no interferance on the intake side from my brake master cylinder so if you have ABS and the motor is on the passenger side you should be good.
My guineapig was originally CA18DE. I used the CA's driveshaft. I seem to remeber something about the KA's driveshaft being different somehow where the dust sheild has to be removed from the transmission, research that. If the length is the same as a CA shaft and there is no interferance you a are set, you can do what I did.
I used a motor mount from one car on the left and a different car's mount on the right to get mine in. I reccomend you make some purpose-built mounts. The crossmember for the CA puts the mounting pads close enough to where the FJ wants them to make custom mounts pretty straightfoward. If the KA is the same peice, and I assume it is you are good to go. I leave it to you to verify this. If they are the same the FJ oil pan will also clear.
The easiest transmission to use is the RB20. whawhawha? that's right. The RB 20 bellhousing will bolt up to the FJ20 if you remove one dowel and don't use one bellhousing bolt. The RB20 box also puts the shifter dead center in the shifter hole of the trans tunnel on the S13. This is key, if you want an off the shelf solution for the crossmember I used an R32 Skyline automatic crossmember flipped around backwards. I have a suspicion the KA automatic one may be the same stamping. Again, you will have to research that.
For running the thing I would highly reccomend you ditch the factory harness and go with an aftermarket EMS or if you are crafty use a Pulsar GTi-R harness and computer. It uses a distributor and is a 2.0 liter turbo engine too, pretty convenient. You could use a regular SR20DET harness but you will have to run aftermaket coils and plug wires because the OE SR coils won't fit down into the FJ's valve cover to get to the plugs. You will need to hach the CAS plug off the harness and wire it to the FJ distributor. The four wires coming from the base are the same four pins in a CAS, neat huh?
Just a few tidbits I learned messing with the thing. You will be on seldom-walked ground sir but The fact that you wanted a CA says you are a bit off, the FJ is off the deep end baby. I won't lie to you it will be a ***** of a project but man, if you could get to run imagine the pride you would have. Balls in your court.
