You definitely got wheels with offsets that are to negative for the coupe "as it is". The wheel set-up would look a lot better if you slam your coupe and tuck the wheels inward. You'll need to do some additional suspension modifications to make your wheel set-up work. Keep in mind that if you lower your car, your wheels will hit/rub/damage your fenders. Rolling your fenders may not be enough to prevent rubbing, but it's hard be 100% sure from the pictures you posted.Agaskin1695 wrote:Haha tell me about It, it looks like a mini monster truck!! And yea I've checked out Teins and they seem like they'll suit me best. Good thing I didn't pull the trigger and got the bc's
Also, as you brought up camber I was planing on just getting the fenders rolled wouldn't that fly-by opposed to getting camber because honestly I dislike the "broken" look
Nah, the current one will fit fine. It will certainly need fine tuning and massaging but it will fit.seldomseen wrote:Lowering your car with coilovers/springs will most likely cause you to experience major rubbing due to the wheel's offset being to negative. (pokes out to much). And based on what you've described and the pics you posted, you may need to purchase a new set up wheels with the correct offset if you wish to lower your car without having any wheel rubbing issues. Your alternative would be to do some fender modifications to make the wheels fit with a drop.![]()
Let us know how matters materialize,
Hell nah...those wheels will not fit with simply tucking the wheels and trimming the fenders. The offset is way to negative according to the pics.alphapig wrote: There are people on here who run 9.5 +5!!
The tires are already stretched well. Just needs a little bit of camber.
Also, I recommend getting the inner fenders trimmed off.
You can even do it yourself if you have a dremel and a steady hand. Much more effective than rolling, and less risk of damaging the paint.
