finally went to the track...
quiksilvia
Car: 95 s14 se
went to the local 1320 and did alright, only got 3 freggin runs, i got like 8 last time, but o well. first one was a 14.6 at 96 mph with a .450 reaction and a 2.2 60' time. 2nd one was not tight and i dont even want to talk about it. 3rd run i launched at too high rpm and i just roasted em for too long and pulled out a 14.8. i wanted more runs but whatever, i think i could have beat a 14.5 too....
silva180sx1515
what kind of boost were you runnin?
ride4lame
those are decent times. my best is still 15.3 on a redtop. stock boost. hahait bogs like crazy though because i don't recirculate...
VitaminT
Car: 93 240sx SE
Hehe I ran a 15.8 on a SR. stock boost, but didn't bog. Just spun the all season cheapo radials through 2nd. I need good tires BAD.
Quick...nice time. Maybe I can get there one day. 2.2 60' is what I need right now.
f150intally
You guys running bonestock? SMIC, stock exhaust, etc.?
240SXer
Car: 1995 240sx SE (2jz powered)
Best I've ran stock is a 14.9.. I'm at 2700ft though. Best run was 13.932@102mph, that was @like 12 psi
VitaminT
Car: 93 240sx SE
I am running, SMIC, 8psi, really crappy tires, don't know how to drag, 3" turbo back exhaust except for the O2 housing.
f150intally
VitaminT wrote:crappy tires, don't know how to drag
These are the two most important factors to drag racing, as I quickly found out.
#1 - Go buy some drag radials, before buying LSD#2 - Practice launching your car. All the skill is required in the first 60 ft. The rest of the race is just the car working (as long as you don't miss gears)
I knocked over 4 tenths off my 60 ft time between the first time ever at the track and the end of the second day. 4 tenths is almost a full second in the 1/4.
VitaminT
Car: 93 240sx SE
I am. Waiting on the D2 coils to see if my current wheels clear before I buy tires.
Oh, I also have a VLSD. Forgot to say that earlier.
240SXer
I get low 2.1s on my balled Kumo 712s (225 width). I've got VLSD though. But that's only when it want to grab. I've got to launch at about 4k to get a 60ft like that, but at least 30% of the time lanching at 4k it'll just smoke though first gear.
dj_lennon_franz
Car: 1992 240sx
its all in how u get outta the hole and how to keep the motor in its power band (yes the SR has a small power band because of that baby **** T25 turbo) i went from running 18.5 to 16.8 on my stock KA24e (well i had an aif filter and a muffler but thats hardly MAJOR mods) ne ways...i ran 14.8@97mph on 10psi and a FMIC...given i dont drag race much ne more i dont think thats too bad (my launching has gone to ****) but learn how launch and bring down them 60fts and keep the car in its power band and ull notice yer times going WAY down (DONT REDLINE THE SR ON THE STOCK TURBO...you lose alot of top end power because of how small the turbo is...shift around 6500-7000 rpms to keep the power up decently)
creophus
Car: 240SX SE & 200SX
Thanks some good info. I gotta get to the track someday...someday soon I hope.
Red_Liner
Jeez, i thought SR's were faster than that....
DriftS14
Uh-oh...
Red_Liner
...........*covers head with pillow*
DriftS14
LMAO! Good idea. I'll duck with ya.
Zadok
Car: '99 30th Aniversary Legacy L
what the heck?you guys are running High 14's and low 15's on an SR?I ran a 15.9 in my KA with a test pipe!I'm looking to run mid 13's @ 15psi in my SR.I raced my friends STI and we were pretty close.And they run 13.2 stock!
Here's a good bit of advice for those of you that don't drag much!Learn how to powerbrake your car and DO A BIG *** BURNOUT!Even if you only have an open diff, you will still get better traction if one tire is sticky. That way you can rev it up and dump the clutch out of the hole!Also, dump it when the last yellow light ignites! you should end up with a .500 - .700 RT. Which is not to bad for a rookie.And here's the last rule of thumb, BEAT YOUR CAR LIKE IT BELOWS TO SOMEONE ELSE! You'll run good times!
Red_Liner
"Learn how to powerbrake your car and DO A BIG *** BURNOUT
That way you can rev it up and dump the clutch out of the hole!"
Dont do this....Big burnout on DOT tires wont do u squat..
spin them up to clean em off gave me the best 60 foot
dropping the clutch doesnt work..well at least for my car....i have too much low end torque...no matter how i launch i get a bad start....
but ya, high 14s for a swap sucks....i did that with a Boost Controller, Cone filter and no exhaust
quiksilvia
Car: 95 s14 se
15 flat should be stock for sr right
Zadok
In my Ka-T I found that doing a burnout always helped my launch!I have always had an open diff though!If I pulled up to a light next to a supra or camaro or something with some HP, I would flip on my line lock and do a big smokey burnout. Part of which was to taunt the other person and psyche them out, and I would always rip them off the line!I know that it has been written time and time again that heating up your tires doesn't work with DOT rated ones, but it has always worked for me.And all the times I didn't, I would spin, roast my clutch, or bog out!I'd just rather rip out of the hole!But that's just my opinion on my cars!
Fish240
Car: 87 corolla gts
quiksilvia wrote:15 flat should be stock for sr right
uh i dont know, my friend ran 14.1 with just down pipe exhaust and filter, his car use to seem slow because his blow off valve was making it slower, try running the stock recircic i think most people will get better times, no cool pssssh sound but it makes a difference
Red_Liner
"If I pulled up to a light next to a supra or camaro or something with some HP, I would flip on my line lock and do a big smokey burnout. Part of which was to taunt the other person and psyche them out"
yeah, one tire fires always psyche other ppl out....
u know what psyche's em out....open downpipe and 22 psi....the turbo screaming.....
ya, i loved the looks on ppl's faces when they see my Volvo pulling away from their so called "fast cars"
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
enjuku ran a 12.8 on their stock T25, I would imagin with totally stock everything including boost, the car should be good for low 14's with the same driver and high 13's with basic modifications.
SRdave240
i ran a 13.8@100mph. Stock turbo 13psi. My buddy with a similar set up ran about the same. And we were thinking we were too slow! LOL
tsk, tsk. There is no excuse to not be in the low 14's with an SR.
dj_lennon_franz
Car: 1992 240sx
best my bone stock SR did at 3000ft above sea level (here in vegas) was 15.1...its all in how you drive it...im sure it would have broken 14s with 100 octane
RobDET
Car: Cars
I ran a 13.4 @ 105 on the T25, street tires, and 14 PSI. My best time at stock boost is a 13.9
I have an S13. Those times were on 205 40 15's with stock suspension. I have pretty much all the boltons except a turbo elbow and a tublar exhaust manifold. I'm also running the stock TB, Intake manni and cams.
Be sure your timing is @ 15 BTDC. Mine was at 5 BTDC and i couldn't break 14.2 @ 12 PSI
USDM_OneVia
Car: Racing
*flame suit on*
14.2 @ 99mphCA18DET powerStock Turbo (crappy t25 with a .48a/r)Stock Boost (10psi)Stock Exhaust systemGReddy VSPL FMIC3 inch downpipeWalbro 255
That's it....
I'm with the other guy.... I thought SR's ran low 14's with VERY little help.
Joe
DriftS14
They do. Mine did. Many others did. So far only the few I've seen on this thread haven't.
AznRide
Car: Cars, hondas, import cars, girls, cars, girls, girls, and more beautiful girls.
I just went to the track today, no RPM gauge, no Speedometer, and ran 13.6 with a 2.0 0-60'. All 3" from turbo down, fuel pump, fmic, and at 14psi. 18" tires, but I kept practicing launch and did it well today. Also brought home another trophy...hehehe
