Sil80315 »
https://forums.nicoclub.com/sil80315-u36835.html
Thu Sep 17, 2009 7:19 am
This is the second time I took the car to the track since the rebuild, The first time I took it to the track it ran 14.3 with open diff and crap tires. Now it has a welded diff and a little better tire but not a drag tire.
Specs92 base model coupeSr20detHKS step 2 cams 264Enjukuracing t3/t4 50 trim 63a/rDenso 555cc injectorsEmance Rom tuneSuspension: Tokio Blues with sportline springsTires. Kumho Esta 225/50/15
best pass was 12.48 But I cant find the time slip for that so I can only post my second best
This pass was at 15psi
R/T.......836
60'.......2.076
330......5.513
1/8.......8.226
MPH......88.59
1000.....10.547
1/4........12.503
MPH.......115.19
My 60 foots suck but its the best I could do with those tires and riding the clutch out, If i didnt ride the clutch it would bog (was leaving around 5k rpm)
My trap speeds range from 115-117 which is a good MPH for high 11's but I cant get off the line for s***. I turned the boost to 19psi and all it did was wheel hop, then spin when boost kicked in and got all lose going into second and the extra boost just helped me catch up on top end and run the same numbers.
All in all im pretty happy running those numbers with what the car is equipped with
what you guys think?
