Finally took the car to the dyno
Sil80315
Car: 1991 Nissan 240sx
Well I finally got the chance to put the car on the dyno just before winter hit us here in Central NY.
Car put down 372whp and 302trqCar was popping right around 6100rpm due to the fact I didn't get a chance to order my bkr8's so the bkr7's were getting blown out under boost.
Sr20detHKS step 2 264 camsISIS intake manifoldEnjuku Racing t3/t4 50 trim .63 a/r turbo at 17psiTurbo Fab top mount manifoldTurbo Smart wastegateDenso 555cc injectorsStock bottom end with Fresh rebuild and Clevite Main and Rod bearingsARP Head studsCosworth headgasketWalbro Fuel pumpZ32 MafEmance rom tune
I was shooting for 400whp but No plugs were to be found
Stay tuned for the video
zach-Ka
Car: 1990 240sx (SR)
Pretty impressive numbers.
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
idaont like dyno charts over speed. i like them over rpms easier for me to understand. lol but nice numbers.
Sil80315
better?
Sil80315
pauliedrft
Car: 91 240sx
so your telling me 550 are good for 350whp Cause if your only running 555 for almost 400 whp that's nuts. Please clarify just in case its a typo lol . Great number and your running the samer turbo as me i love the spool characteristics .
Sil80315
Yup I was running 555cc's at 80% duty cycle.
The 555 are good for 440hp with good Tuner and the right fuel set up and a good FPR. You can push the injectors into 600+cc's just by fuel set up alone
Im switching over to 740's or 72lb injectors over the winter only because im going bigger turbo.
Justin35ll
Car: s13 coupe sr20det
Nice man, any pics of the bay?Interested only because I'm starting to look for big turbo setups. Can't wait to finish building my block.. How are those hks step 2 264s too? I was looking at getting them.
Do you have springs, retainers, and valves too?
pauliedrft
Car: 91 240sx
Sil80315 wrote:Yup I was running 555cc's at 80% duty cycle.
what octane are you running , would a aeromtive fpr be good enough its good for 1000hp , cause im trying to figure out 810cc or 550 and are those totyota injectors 2jz if so what mods did you have to do to get them to work and how much did you pay for your tune ???Cause i can have some free one from a friend .when he does his upgrade to 1080cc to run e85 .
Sil80315
Yeah I have the brian crower springs and retainers that enjuku sells.
The cams are an awesome upgrade and they just keep making power on the high end of the rpms. I also have a 272 exhaust cam that Im thinking about installing
Sil80315
pauliedrft wrote:what octane are you running , would a aeromtive fpr be good enough its good for 1000hp , cause im trying to figure out 810cc or 550 and are those totyota injectors 2jz if so what mods did you have to do to get them to work and how much did you pay for your tune ???Cause i can have some free one from a friend .when he does his upgrade to 1080cc to run e85 .
I was running 93 as I always do. The only reason to get into e85 is really just for dyno numbers or full blown drag car. If its just a street car then just keep it on a pump gas tune.
I get my tunes from emance but Im also thinking about switching to nistune for the next build
240driftersr20det
Car: 1992 240sx Hb w/ 1993 red top sr20det
Nice engine bay! looks really clean. but why that paint on the exterior? get some shiny gloss!
Sil80315
240driftersr20det wrote:Nice engine bay! looks really clean. but why that paint on the exterior? get some shiny gloss!
All the money went into the engine bay
pauliedrft
Car: 91 240sx
hey sil are the injectors your using 2jz injector's and are they direct fit no mods .cause i can get my self some free ones if 2jzgte ones are what your using .
EnjoiNismo
Car: 93 240sx
wow nice numbers!
Sil80315
pauliedrft wrote:hey sil are the injectors your using 2jz injector's and are they direct fit no mods .cause i can get my self some free ones if 2jzgte ones are what your using .
Nope im just using your run of the mill side feed injectors you can buy at any 240/sr website for fuel upgrades.
As for the 2jz injectors. I dont think they will fit. Look up our injectors with supra injectors. Their injectors look to be fatter and shaped differently then injectors for our fuel rail.
People say the STI injectors fit if you can get your hands on those. They are also 550cc's
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
Man that intake mani is killin your tq just like it did mine when I went top mount. I honestly would never go with anything but oem intake on an SR unless I was drag racing and trying to make north of 450whp. The tq drop and area under the curve just isn't worth it IMHO. I made 345wtq with oem intake at 20psi on a GT2871R and switched to the isis and top mount 30r and made 311wtq at 18psi. I had to run 25psi with the 30r just to get my tq back to 340. IMO, i would rather have 380whp 350tq at 20psi on the 50trim then 300wtq with the isis intake. Just my opinion from trial and error and the feel my car had on the street with each intake. Also it was much easier to launch at the track with the stock intake.
Anyways, if you gapped the BKR7's down to .025 or so then they shouldn't have blown out. You may have a coil pack problem?? I gapped my BKR8's at .025 and ran as much as 28psi on 110 and never had a spark problem with oem ignition.
Sil80315
yeah thanks for the input. I plan on switching to a full race manifold and a gt3076 or a turbo equivalent. im shooting for 450+ whp next year and that should be the turbo to get me there. Im also going to do alittle more head work along with rods.
ive seen numerous dyno runs with the sr making crap for torque reguardless of the manifold/turbo set ups. If i wanted to increase torque im better off increase the displacement
