They will proably use a battery and "rig" it to the motor for it to crank over. Since that is all you will need to do in order to properly get compression to build.S13 240SX wrote:ugh... how does one check compression without cranking motor? doesn't engine have to be cranked?
WOT- WIDE OPEN THROTTLE (this means that they hold the throttle body open 100% so it can intake air into the combustion chamers.S13 240SX wrote:what is a WOT compression?
ATF Fluid= AUTOMATIC TRANSMISSION FLUID its mostly red in color, and is a little thinner then straight oil. They use it as a lubricant to seal up the rings so there wont be any compression seeps.S13 240SX wrote:ATF fluid in cylinders??? WTF?
Its a little difficult to explain. Use the search button, Im sure they now how to do all these test. Good luck. BTW a leakdown test deals in some part of cylinder pressure. It lets you know of a leaking cylinder.S13 240SX wrote:yeah but i still don't get it why not just use regular oil...
and how is a leakdown test done?
