Arrow »
https://forums.nicoclub.com/arrow-u15687.html
Mon Jun 22, 2009 8:29 am
So, it's been a while since I updated this build... I picked up the block from the machine shop this past weekend and have started to get everything ready to be reassembled. I also now have all of the gaskets, bearings, and such to have a good'ol time!
Right now I am painting the block and will then hone the cylinder walls myself - they don't need much, just to break the glaze and give the new rings the ability to bite into something and seat themselves.
Now I have a question for you any of you that know the answer...
I have thought about removing the emissions crap while I am doing the rebuild. I know that many people do this, however, it seems like many (if not all) also have a modified ECU or piggyback for other reasons (like turbo, or an extreme n/a build).
My question is this:If I was to remove the emissions equipment would I also need to tune it out of the ECU so that it doesn't run in closed loop and hinder performance by running richer and not really taking into account some sensors that monitor A/F ratio?
I am planning on keeping the necessities "visible" (EGR and AIV mainly) just not have them functional so that I can clean up the engine bay. However, if this proves to create more problems than it's worth, I will probably just scrap the plan and just keep everything on and functional.
Thanks to those keeping up with my progress!
