FINALLY SOME PICTURES *LOOK*
bryantkalagian
Car: 96 240sx
MOTOR:-BR25DET Series 2. 20,000 original miles. Oil changed every 2,500 miles with Royal Purple full synthetic.-Physco motor mounts -R33 5-speed transmission -new turbo from an R34 (slightly bigger, more boost-while still being turn-key)-HKS intake-3 inch turbo back exhaust, 3" Magnaflow high-flow cat, Trust carbon fiber muffler-Greddy Type RS blow off valve -Greddy timing belt-CX Racing front mount intercooler-CX Racing aluminum radiator-custom 1-piece aluminum driveshaft-HKS Type-0 turbo timer-Prosport gauges (boost, oil temp, air to fuel)
SUSPENSION/BRAKING:-K-Sport Pro Controll coil overs-Tunabe sway bars-drilled and slotted rottors all around-performance brake pads all around
INTERIOR:-NRG harness bar-gutted back seat-4 point Weapon R harnesses-(still have all original back seat stuff, a few bolts and it's back to stock)-custom interior lights, gauge back lights-Sony Explode head unit with iPod hook-up-new speakers-carbon fiber style shift knob-carbon fiber pedals
EXTERIOR:-custom Dark Burnt Orange paint with black top (less than a year and a half old)-aftermarket tint all around- crystal clear head lights and corner lights-black front bumper lip-black stock 5-lug rims-front license plate relocation -new Lexani tires-de-badged
Thanks for all the help over that last couple months
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
nice, I like
virus77
Car: 95 S14, 71 240z, 97 e320
Looks good, some wheels would really set it off. Is that a carbon cover for the rear seat area?
neonbomb
R34 rb25s have bigger turbos?
bryantkalagian
Car: 96 240sx
yes it is. to cover the hole in between the trunk and back seat
bryantkalagian
Car: 96 240sx
ya just barely. or maybe the just put out more boost. either way my stock turbo was blown and i got a good deal on the r34 one
virus77
I've got a r34 neo turbo as well, the original turbo crapped out and my friend had a neo one available so I used it. The compressor is the same but the turbine housing is considerably bigger. The wheel also has different number of fins and is made from a different material. Spools slightly slower than the standard turbo but has slightly better top end... I havent tested to see if these are prone to snapping wheels off like the older turbos but I spike 16 and boost 15 regularly and its been fine so far. It is a direct bolt on, only other difference was the wastegate nipple points in a different direction. These are my personal findings so far on the r34 neo turbo.
bryantkalagian
Car: 96 240sx
well there you go! hahathank you
Cjmartz2k
Car: Hunting for a '89 GTR now
I'm pretty sure all the RB25 turbos are the same size, and the only difference is the new ones have nylon compressor wheels which should in theory make them spool just a touch faster. That's what all the guys with stock turbo's and dyno graphs show on Skylinesaustralia.com at least. Not certain though, so don't take it as gospel.
It's damn good to see somebody mounting aftermarket safety harnesses correctly though. I can see you enjoy the use of your spine Nice clean looking car man, I like it.
bryantkalagian
Car: 96 240sx
maybe, i dont know. check out what this guy told me:
"I've got a r34 neo turbo as well, the original turbo crapped out and my friend had a neo one available so I used it. The compressor is the same but the turbine housing is considerably bigger. The wheel also has different number of fins and is made from a different material. Spools slightly slower than the standard turbo but has slightly better top end... I havent tested to see if these are prone to snapping wheels off like the older turbos but I spike 16 and boost 15 regularly and its been fine so far. It is a direct bolt on, only other difference was the wastegate nipple points in a different direction. These are my personal findings so far on the r34 neo turbo. "
so im not sure if you or he is right. what do you mean by mounting the harnesses right? ive heard a couple people say that...
Cjmartz2k
Now I know that dude is full if it about the turbo. They ALL come with ceramic turbine wheels. People got confused about the fact that from the newer on up (kouki) RB25's, they had a nylon compressor wheel, and some how that got turned into the common "internet fact" that the turbine wheel was made out of steel. Now you might have a VG30 turbo or something like that. They have a bigger exhaust housing/wheel. I think some of those might have steel wheels, but I'm not speaking from first hand experience there.
About the harness, a lot of people just got over the top of the seat and right down to the floor. If you do this and come to a sudden stop which would actaully require the use of your 5 point harness, thanks to the geometry, it'll compress your spine straight down instead of just holding you from going forward. You have to have the bar behind the seat at shoulder level, just like you do. There have been instances (I've read about, not seen) where people have seriously hurt there back getting in low speed fender benders by wearing 5 points incorrectly installed.
virus77
The material could very well be the same, they just had a different color to them (oil, egts, wear and tear) so I assumed it could have changed since the turbine housing was a different size, i didn't go into doing a test to see the composition of the wheels, frankly its a stock replacement turbo and I could care less. I assure you the turbo I used has a larger A/R housing then the standard 25 turbo this along with the discoloration led me to think its possible they switched materials. Or it could be I got a wierd turbo which someone claimed was a neo turbo which perfectly bolted on to the stock manifold/dpipe/intercooler outlet and it had a different housing which I am assuming is a neo. Regardless none of what I said if from the "internetz", its from what I saw on my own car so spare me your elitist bulls***.
EDIT: quick thing I pulled from the internetz while were at it since I being accused of a internet regurgitator
Changes to the engine included a new NEO head which contains solid lifters and revised variable valve timing A slightly larger exhaust housing on the turbo is used to improve flow, and the compressor wheel is now made of Nylon to reduce lag. A larger side mounted intercooler was also added and is efficient for levels up-to 200rwkw. Acceleration times remain similar to the nissan skyline R33 as it is a slightly heavier car.
Modified by virus77 at 5:25 PM 10/28/2009
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Cjmartz2k wrote:About the harness, a lot of people just got over the top of the seat and right down to the floor. If you do this and come to a sudden stop which would actaully require the use of your 5 point harness, thanks to the geometry, it'll compress your spine straight down instead of just holding you from going forward. You have to have the bar behind the seat at shoulder level, just like you do. There have been instances (I've read about, not seen) where people have seriously hurt there back getting in low speed fender benders by wearing 5 points incorrectly installed.
I agree that the harness bar is in a decent location, but I would NEVER have more than the standard 3-point belt without a 4-point "cage" at minimum. If you roll a car without a cage and you have harnesses keeping you positioned upright, your head has nowhere to go but be smashed down by the roof. With a 3-point, at least your body will rotate to a side and hopefully out of harm's way. That's MHO.
