hey all,
just wanted to say thanks to all those who helped me out via nicoclub and emails with my questions. especially skillzilla and his write-up (
http://racebread.com/files.htm, and its clearly marked rb20det into s13 by skillzilla), very easy and clean writeup for any new guys trying to put in an rb20det into an s13. she just fired up today, i was getting her to turn but not start and i realized there was an issue with my ignition relay wire.
"10) Using your voltmeter, find a wire from the S13 grey plug that shows 12V when the key is in the ON position and 0V when the key is off. Also, ensure it remains at 12V when the key is in the START position. Connect this wire to the white/purple from the RB harness. This will tell the ignition relay when to turn on."
i found the said wire in the brown plug by the fuse box, NOT the grey plug, just incase anyone uses this write up and has the same problem.
anyway, pictures will come soon, still waiting on my koyo to come in the mail, and then its off to get paint. give me a week or so and i should have pics up.
by the way, i will also be trying to put in a maxima gauge cluster with the white faces, and see if that works so i can avoid the resistor for the KA gauges, ill let you guys know if it works.
