Finally runs but still neewd some help !!!!
preston240sx
Car: Nissan 240SX S13
First off it runs but i have an oil leak coming from my spark plug rubber seal but when trying to pull the spark pluggs out all the rubber seals came off my pluggs now i can't pull my spark pluggs ? any one ever have this and how did you finall get the rubber seals out and how ??????
thx Preston
fiznat
Car: Grown up :(
hahaha yup, that happened to me. Taylor spark plug wires? They are a real pain to get out... what I did was actually take a flathead screwdriver and notched it with the chop saw to make a sort of pick/grabbing tool.. that took them right out.
I ended up just removing those plastic ends, you dont need them..
As far as oil leaking into the spark plug area, did you remember the middle spark plug gasket on the valve cover? There are 2 thick rubber gaskets...
preston240sx
aight thx for the info i'll try that tomarrow as for the gasket that go's ... it to the value cover where the pluggs go i put it on but im guessin maybe its bad cuz its leakin into plug my cylinders..... had white smoke comingout exhuast ... i just replaced my head gasket that why i was on down time thx FIZZZZ
fiznat
Car: Grown up :(
I thought you said you had oil leaking into the spark plug holes?
White smoke is coolant leaking into the combustion chamber, which is usually a headgasket issue...
preston240sx
i do have oil leaking in and im sure its oil because you can see it leakin out from the spark cover it was all over my spark plug spocket i dunno i'll have to take pics tomarrow thx fiz
