I30T »
https://forums.nicoclub.com/i30t-u8394.html
Sat Aug 02, 2003 2:53 pm
j30t, i think he might want to have one with him and have one as a backup in case of lost keys/locked keys in car or let someone else have keyless entry also.
anyways, here, i tried to get this from nissan-techinfo.com, but they charge money. Found it on a message board.
Quote »1. Open the trunk
2. Close and lock all doors
3. Insert and remove the key from the ignition six times within 10 seconds
4. Manually unlock and lock driver's door once to enable "setting" mode
5. Push lock button on the new remote controller once, just long enought to hear it beep (BTW, mine didn't beep! Don't worry!), within 5 seconds of completing step 4
6. If additional remotes are needed (up to 3), repeat steps 4 and 5 for each additional remote immediately after programming the first remote (note: a total of four (4) remotes can be programmed to funtion on the same vehicle)
For addtional information please refer to page BF-38 of the 1993 and 1994 J30 Service Manuals.[/quote](by the way, does anyone know where i can get a FSM for i30t?)
Also, I found out recently that if you hold the unlock button down on the remote, it lowers the driver and passenger side windows for some reason. You cant put them back up with the remote, but you can't lower them.
