finally pics of my RB powered spitfire
rbspitfire
here are some pics of my spitfire thats almost complete, i had to build a new everything, crossmembers, firewalls, transmission tunnels dashboard...
rbspitfire
i cant figure out how to post more than one so i will put them on seperatly
rbspitfire
you will see i even had to move the turbo.
rbspitfire
my main problem is that my downpipe is about 1.5-2" off the ground
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
that is frackin awesome, I like the turbo relocation.
rbspitfire
this car makes a miata look big
rbspitfire
rbspitfire
it only weighs 1700lbs it pulls like a 12 second car and its stock unintercooled.
rbspitfire
to give a perscective on how small it is im only 5'10"
kouki-gymkhana
Car: 1993 Nissan 240SX (only 90,000 mi!)
Awesome swap!! Looks like you spent alot of time figuring out how to make everything fit. One question though...why are you leaving it unintercooled??? I'd think you'd need at least the stock SMIC to make some respectable power and to bring the intake temps down to a respectable level.
Carl H
very nifty swap, but you need to recirc the bpv else it will stall...
gbaz77
Car: 240sx
thats really sweet. cant wait to hear some stories of pulling up beside an unsuspecting mustang or even a corvette. congrats on the swap. very clean.
btw im sure there are some tiny intercoolers you could put on that 'u' pipe you made there, just to even give it a little bit of cooling.
rbspitfire
im actually running a meth injection system, so i can have cooler temps and when i put a bigger turbo run plenty o boost! i used to run 24psi on pump gas on my GN!
REDLN
Car: 95 Nissan 240SX SE
sweet swap you did a lot of work on that. That look like you have a small radiator too. any video's of it running?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
nice project, very nice.
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
That is such a cool project! Now all you need are some 9" meats on the back for traction
I can't wait for a video of it in action!
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
That is awesome! Good Job! Question: Did the doghouse roll forward from the factory, or did you do that yourself as well?
kjlindgr
Looking at a car with an engine that doesn't belong in the bay is cool. Good work.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
Carl H wrote:very nifty swap, but you need to recirc the bpv else it will stall...
werd, i ran mine like that and it would die out. NICE work though!!
kouki-gymkhana
How much boost do you plan on running?? (Hopefully not 24psi on the stock bottom end!)
rbspitfire
i plan to run 15-16psi with a good t3/t4 and bigger injectors.
hannibal
Car: Red Line to Glenmont
Wow, very unique project. Nice job!
