Finally manual
rtm240sx
Car: 97 240sx
I just got done doing my auto to manual swap. Well worth it .
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
...lucky
Thamm
Car: 2001 Lexus IS300, 2003 Toyota Matrix, 1993 Honda Civic
nice car. more shots of it please!
rtm240sx
Car: 97 240sx
Will post pics later car is in shop right now for ecu to get pined out.
rtm240sx
Car: 97 240sx
Thamm
very nice
motoman399
Car: 98' wrecked (RHD coming soon) 240
i've got a 98 with an auto. i also have a wrecked 95 with a stick and everything to go with it. did you have to modify your firewall to get the master cylinder in? and what about your ecu is it at the shop cause of the manual? thanks
rtm240sx
Car: 97 240sx
Yes you do need to cut a hole in your firewall to install the mastercylinder and clutch pedal. The auto ecu will throw codes and your engine check light will be on.
motoman399
so think i should change all my wiring harness to the 95? im planning on turboing this car
addisonblck
Car: 93 se mods soon to come
Sc300 1jz swap laundry list of goodies
gets rid of the speed limiter though. well after u unplug sum stuff
motoman399
addisonblck wrote:gets rid of the speed limiter though. well after u unplug sum stuff
haha i already have 10 tickets and im 20 so i dont think i really need to remove it
240_fun
Car: 92 Nissan 240sx Hatch, 2000 Ford Ranger XLT
yehh lucky...Its too cold to do anything in NJAuto sucks...You got any tips for the swap?how did u get the auto pilot bearing out?
rtm240sx
Car: 97 240sx
The only real good tip I can give is to do your research before getting started. And before you start make sure you have everything. My friend pulled out the pilot bearing since he has done this kind of swap before.
