I finally got my car running right. I guess I had a 3 psi wastegate spring in. I replaced it today with a 10psi spring and it works like a charm. It is about dam time. I just wanted to thank everyone for the help you gave me. I am going back to the dyno and I will post my dyno sheets up when I get them.
t3 super 60ssac manifoldtial wastegate 10 psi springspearco front mount intercoolersafc 2370cc injectorswalbro fuel pumpz32 mafsand all necessary electronics
At first the maf was to close to the turbo. So I switched it over to the cold pipe and did the blow thru maf setup that made the car work perfect other then I needed to tune the safc. The second problem I had was I bought a 10 psi tial wastegate but it came with a 3 psi spring. So I bought the new 10psi spring and now I no longer have any problems...For now. It works out perfect since I wanted to get the car done before I went to guam on deployment and now it is done. One thing less I have to worry about. I didnt want to come home to a car that didnt run properly. What are the low afr suppose to be when not in boost? I know that in boost it should be as close to 12 as possible. Im just not sure about when not in boost. Thanks
Modified by 98240 at 10:25 PM 4/7/2006
Postby
98240 »
https://forums.nicoclub.com/98240-u35691.htmlSat Apr 08, 2006 7:55 am
I went to the dyno and at 7 psi i had 185rwhp. The thing about it is I dont hit full boost until 4000rpm. This sounds strange since I thought the t3 super 60 were suppose to be instant. Also when I was leaving the dyno I noticed that I was only able to boost to 5psi this is strange also. I dont understand why it is taking me so long to get to full boost. Anybody know?
Postby
Kittychubbs »
https://forums.nicoclub.com/kittychubbs-u39310.htmlSat Apr 08, 2006 8:42 am
how does the ssac manifold look?i heard the megan downpipe fits it!!
my turbine its a Type: T04ET3/T4A/R.50 on the front face of the turbo on the back brown side its A/R63
so well all i need its the intercooler pipes and a downpipe!! and if i have a FMU do i need the Sr20 injectors? i heard no but what better i want to gte the injectors since i have a z32 maf n fuel pump. thank u!
HI Gentleman Quick question: does a SSAC top mount manifold be compatible with an SR20deT downpipe??My turbine its a T04E. i heard megan works humm?? and whats a good BOV its external good in the long run or internal?? greedy hks blitz?do i only need the downpipe or do i need a Turbo outlet too?? Can anyone send me a link of ebay or sum store of the part u would get if u had to pick THANK U!!i know it a random question but u guys are reliable in ur anwers so dats why i ask thanx again! ^o^
The downpipe connects to the turbo not the manifold. If you need a downpipe go to a muffler shop and they can make you one. If you dont want to get one made at the muffler shop then look on ebay.Check out nico's sponsors
98240 wrote:I thought 7 psi would at least get me in the 220-240rwhp. I am sure nothing is wrong with the wategate. I just pulled that out and fixed it yesterday.
seven psi should have net you more than 200wrhp on that turbo. as for y ur boost is coming on that late, i had the same issue and it was a stupid boost leak from the T on the compressor housing. one hole on the T went to the wastegate but the other one was left open lol. rubber cap and zip tie and instant spool was where i was left at lol.
Postby
Kittychubbs »
https://forums.nicoclub.com/kittychubbs-u39310.htmlSun Apr 09, 2006 6:13 am
hehehe Ur right so sorry ooops yes it connects to the Turbine oh i found a bunch of downPipes - Sr20s on ebay none for KaT your link pic didnt work well peeps say for me to get a Megan DP and then go to a muffler shop and get the connection to the back of the turbo custom hummmand the o2 sensor i take it from the one already on the car right, well Thank u for the help
I finally found the culprit to my low dyno numbers and why the boost was kicking in so late. On the ssac manifold there is a hole with a fitting in it. I plugged it up with jb weld but it came out the same day and I just never noticed it. Then my friend was like what is that on the manifold. I was like i plugged it up that isnt it. So we checked it anyways and it was blowing alot of air out. I plugged it up and I have alot more low end power. My boost kicks in alot faster but I have to test it later since I never put the light in my boost gauge.
