gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Jun 08, 2008 1:59 pm
That is the main purpose of the spacers; to level off the arms or help get the desired arc of travel in relation to the lca.Honestly, i do not have either the vocabulary or the education to justify how my car is set up, fortunately I am blessed to know a couple of guys that do.With the rose end set up using only the larger spacer, the ride was much improved over the Tein rods and ends I was running. However there were still hints of wander, and a couple of hard stops revealed the nose was not quite settled. One side would lock for example, or she would pull to either side repeatedly.I spoke to my peoples, and he recommended both spacers on top and not too much more than 1* neg camber. Outside of deep road seams, the car tracks straight and true, and heavy braking now has the nose tracking straight as well. He mentioned something about re-working the lca's as well to bring them closer to level but some shims or spacers need to be worked out for the sway bar and t/c rod attachment points. Fortunately he knows how to measure, cut, and weld, and I know how to stay out of the way and ice down the beer.However if your car suffers no ill effects from the new settings, enjoy the ride. Also, the washer I was refering to is just that, a large (about 1.5") washer that goes on the bottom side of the ball. Should the ball seperate from the rod end for any reason, the washer will keep the arm from completely falling off and you will still be able to steer.
