Ryan Heo wrote:Honestly I don't know about the engine much so I couldn't ask about the problem more specifically to the tech. I really want to know how to check the compression, pin point test, and how to clean the cylinder. I would like to learn about the engine but the way couldn't be shown to me. $500 for every 6 months... It makes impossible to keep the car.
Thanks.
I've never done a compression test myself so I don't know the details, but it is something you can do in your driveway.You can buy self compression testers at auto parts stores. Basically, you remove one spark plug at a time and replace it with the compression tester, then you turn the motor. The compression tester will record the highest compression that cylinder produced.
