Darius wrote:I don't think you're down on power. My T04Z was making about 420 whp at 20 psi on pump gas on a SuperFlow dyno, which is about as conservative as it gets. Your engine's 8:1 compression is pretty low and could be a factor. If your cams are degreed, timing and fuel are accurate, it hits target boost, and there are no boost leaks, I don't know of much else you can do to optimize the system's efficiency.
Yeah ive come to just except this, however i feel it should be doing more, mainly because the head flows 300cfm has bigger valves. Guys are making power like this with stock heads.. made 412whp on a dynojet with a bone stock RB25 head and cams with a 3076r previously.. on about 19-20psi
Now with the ported RB26 head ITBs cams and a much larger turbo it only gained 65ish WHP it was on 18-19ish psi i also have a larger downpipe and exhaust than previously. Bottom end hasnt changed between the 2 setups the compression is lower because of the chamber difference between 25/26 heads and my .060 head gasket.. Just doesnt add up.. a 6766 is a large turbo capable of over 900whp as well so i just had alot higher expectations..
im temped to change cams or try something to help, ive played with cam timing a bit, but i honestly think this thing should be making at least 550whp on pump gas, the head flows enough to support this..
