Finally had time - painted brakes
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
the djay
Car: 2008 Versa SL HB w/ full tech option
2006 Jeep Grand Cherokee Laredo
1976 Chevy Malibu
I finally had the time to paint the drums and rotors. Went to Canadian Tire and bought some Calliper paint and it only took about 2 hours to "get 'er done"! I'd appreciate any opinions from members. Note: The red you see on the wheels is only the reflection from the paint, NOT over spray lol.
fjwagner
Car: 2008 Nissan Versa S et al
The rotors look good, but the drums do not do much for me.
the djay
1976 Chevy Malibu
Hmmm, I sort of want to agree with you. Seems to be almost a little too much. Will see what others think, and maybe go back to black in the near future. Either way I found some rust starting to form on the drum so this will stop it I hope as a a bonus.
iluvmyVersa08
Car: 2008 Nissan Versa SL Sport
I like the rotor look. I am thinking of doing that to my Versa.
williamk10
Car: '07 Nissan Versa SL
what happens when its time to change the front brake pads? Did you paint over everything?
Red Devil
Car: 1990 240SX w/t SR20
the djay wrote:Hmmm, I sort of want to agree with you. Seems to be almost a little too much. Will see what others think, and maybe go back to black in the near future. Either way I found some rust starting to form on the drum so this will stop it I hope as a a bonus.
It's a lil much but would've looked a little stupid if you didn't paint both. The only way to stop rust is to sand it down and then paint it or use a rust inhibitor primer, usually contains a lot of zinc, on it first. The process of oxidation doesn't stop when you just paint over the rust.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I don't really see the point of showing off drums. If anything I'd paint them black to hide them more. Painting them an eye-catching body color is definitely not the way I'd go. I guess at least you're helping prevent rust spreading to your wheels.
the djay
1976 Chevy Malibu
Used caliper paint that was made for this purpose so I don't foresee any problems with that. I only applied a light coat as well so probably will keep dust and debris out of the calipers. But I do appreciate the comments....thanks.
Return to “Versa Technical Discussions”
