rancidjack wrote:wow, some experts you guys are
First, don't look a gift horse in the mouth.
Second, word your question more clearly. I took the extra effort to look up your previous post, and piece together just what the hell you're asking.
Your idle is too high. If you can't adjust it lower using the IACV adjustment, or ecu adjustment, then a vac leak is likely. You say you have a wideband. Did you install it ? How are you sure it's a wideband ? Assuming it is, the "---" reading is way lean. That could be a big vac leak at idle. Could be a fuel problem too, but lets work on one thing at a time.
But how does the car run under load ? Does it buck, hesitate, pop ? Does it build boost normaly ? Why not pressure test your piping ? (don't just look at it to find a leak)
