I believe that knuckle up toward the stub axle that goes into the trans is for ABS.. my vert does not have ABS.. can I still use this driveshaft? I found that the ABS driveshafts are just a little shorter then the Non ABS ones. Has anyone successfully used this type of shaft when doing the 5 spd swap?
