finally got some money
dbigfoot111
i've asked u guys this b4, but now i have the money to buy it, im plannin to buy oem yellow fog lights, and HIDs 6000k, im just wondering if this is a good combination?here is the HIDs kithttp://cgi.ebay.com/ebaymotors...wItemand here is the yellow oem foghttp://cgi.ebay.com/ebaymotors...ZWDVWtell me wat u think plzplannin to order it this weekenthankyou
08Coupe
Car: 2008 Altima Coupe
I would go for the slim digital kits. Easy to mount, extended bulb life, newer tech..ect.
Same seller~~examplehttp://cgi.ebay.com/ebaymotors...65947
Modified by 08Coupe at 6:42 AM 4/30/2008
dbigfoot111
wat about the fog lights are those any good?
08Coupe
If you have fogs then just change them to yellow hid, if you don't those will need to be fabbed up, make sure of size too..The stock ones are pricey then you need a hid kit, so it may be worth the work...Good luck
dbigfoot111
i dont have fog lights, and im plannin to get it wat do u mean it need to be fabbed up?thanks for the reply
08Coupe
Looks like the second link on your first post has changed, but unless the foglight kit is OEM (factory),most likely a mounting bracket will need to be made to install them in the bumper.
dbigfoot111
here this is the fog, so does it need a mount to be install?http://cgi.ebay.com/ebaymotors...ZWDVW
08Coupe
If you have a 2002-2004.....maby. It says oem replacement
dbigfoot111
i cant find any 06 but will tat 02-04 fits in the the 06 altima? i look all over but still cant find any
dbigfoot111
correction 05 not 06
