Jeff Williams wrote:Very nice. What is your goal HP/TQ?
No, absolutely no way! I'm trying to build a pure driver's car which to me means NA, RWD, manual and no electronics / traction control etc.I'm using an emerald ECU (standalone) as I'm not running the Q intake, but making up an IR manifold with 8 45mm throttles, so will be ditching the MAF anyway. Did look at using a factory ECU, but too much hassle. I spend a fair bit of time tuning them on VG30DETT's and it's nowhere near as easy as using a proper system. Lots of hassle to get the looms matched up too, and I didn't get the loom with my engine anyway.I don't know, I think VH50DE or 500ZX sounds pretty goodRex wrote:So, no FI for this motor?
What are you going to use for "management"? A tuned ECU or a standalone system?
VH50DE ... something seems weird about that.
Yes, probably the best solution, until I can afford a quaife sequential anyway (dreaming).May use a 300ZX NA diff to get 4.1 rear end though.RobertsnewQ wrote:What are you doing for a transmission? VG 'box with an adapter?
Hey, he's using Fuel Injection.Rex wrote:So, no FI for this motor?
But that was on a VH41DE, and I thought he sleeved it smaller. In any case, the cylinder mass area looks like it would be similar in both blocks.John Dixon wrote:The block's been inspected, but I know they've been taken out to 4" (101.6mm) before without hassle (Mirage on here has done it).
