Finally got my sr20 to pass emissions!
civicsi2
It took 2 catco cats and some good tuning from John Reed @ Torqurefeaks but we got it. Some people might be able to get it to pass with one big good cat. I got mine on ebay cheap. Catco are POS cats. This is in oregon and they put it on a dyno and go from 0-40 mph and measure the exhaust emissions. It took me 7 tries and a bunch of little bits of tuning from John. I used 1 catco cat first and that didn't last long. It can be done!!
Now if i can get my crank angle sensor problem fixed all will be quite well.
Heres the mod list: Engine Modifications: - Redtop SR20DET motor - SPEC stage III clutch - GReddy V-SPL FMIC - GReddy 3" downpipe - Enjuku racing hotpipe w/ GReddy Type-S BOV - S15 multilayer exhaust manifold gasket - Braided stainless turbo lines - TurboHoses.com silicone hoses/T-Bolt clamps/Spring-loaded T-bolt clamps - Walbro 255lph high pressure fuel pump - Garrett GT2871R .86 a/r turbo - Nismo 740cc fuel injectors - AEM Engine Management System, GM 3bar MAP sensor, GM IAT sensor - Koyo Aluminum Radiator - Dual 12” flexlite fans - Gm Boost controller - HKS Hi-Power 3” exhaust w/ test pipe
S14 boy
Car: 1997 nissan 240sx(R.I.P) 2003 VW GTI 1.8T 1975 Triumph TR6 Overdrive
thats a really nice sr, but why would you even want to be assosiated with a civic- they suck, in fact all front wheel drive sucks
912.0turbo
S14 boy wrote:thats a really nice sr, but why would you even want to be assosiated with a civic- they suck, in fact all front wheel drive sucks
Get out of here noob.
civicsi2
shows your intelligence level. Your name should be retard boy not s14 boy. If i was a mod i'd change it for ya. Grow up.
thanks 912.0
240dreams
Car: 240's
damn you got that setup to pass? Good job man. Nice SI. Theres a guy at my work that has a 400whp turbo si. I work at HONDA.
Hijacker
Car: '92 240sx Convertible
'94 F-150
play nice guys.
SI, good job. There's another guy here in maryland that passed emissions with his SR. I think the guys at heavy throttle put it together for him.
One trick is to restrict air flow. Smaller exhaust, cats, and air box should all help in that aspect. What style of fuel mapping did you go with? A more lean or more rich approach?
civicsi2
way lean. the smaller exhaust should work too.
eliterit
Car: pignose
hmm,
so i guess one would want to keep their old stock exhaust and use that to get it to help pass then..
nice tips
but we dont have to worry about that much here in texas
ariesoner
Car: 92 180sx RHD
Do you still have your EGR? If you were running really lean without an EGR it seems like the NOX would go through the roof.
civicsi2
not sure if i have it. with my first cat nox did go through the roof when we leaned it out. with the 2 cats the hydrocarbons was really high but the nox was dead 0. so when leaned it out and got the hydrocarbons way down and brought the nox up a bit to like .1. I had a good bit of room to play with with the nox.
slow s13
Car: cars, photo, music
if you weren't routing the BOV back into the intake you should have
Gladius
Hey, civicsi2, I'm looking at your turbo, how's the throttle response on the low end? Does it offer any top end pull? When do you hit 12psi by? 17psi?
mmatl16
Car: 240sx rb20 swap
wow kid u really need to think before u talk. ive got a friend with a swapped integra who murders the swapped 240's around here. ive even seen him slide some corners. not really drifting but funny as h3ll to watch. lol
thats crazy u got it to pass. congrats. id rather just pay under the table then worry bout cats and piping. just me though
civicsi2
Gladius wrote:Hey, civicsi2, I'm looking at your turbo, how's the throttle response on the low end? Does it offer any top end pull? When do you hit 12psi by? 17psi?
Not exactly sure how to answer this. Throttle responce is good i guess, I don't have much to campare it to. Well it reaches full boost at 16psi around 3900rpm. Heres my dyno chart it might help.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
Which DEQ did you have most of your tests conducted? It would be helpful information. congrats!
civicsi2
I really don't think that matters. but sunset one and the clackamas one.
NrG
too bad the sr20 will never pass emission in California. There's a thing call Visiual inspection. Where the motor doesn't look like it came with the USDM car. Instant failure.
Silviapower
Car: 98 240sx SE
in california need a Smog Certified Friend mechanic... get it done...
