FINALLY GOT MY RB26 INTO MY S14
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
Well i finally got the RB26 in tonite here are the pics, THANKS TO EVERYONE THAT HELPED.
The modified rb26 pan worked out great all I have to do is make some spacers for the sway bar and its all gravy.
govtworkhorse
Car: 95 240sx SE, 95 240SX, 91 Festiva (DD), 03 GSX-R 600
Beautiful. I don't know what I'd do with a garage like that. wow...
JerryRigRB240
Car: 1990 240SX Coupe with RB20DET swap
govtworkhorse wrote:Beautiful. I don't know what I'd do with a garage like that. wow...
You might swap skyline engines into 240SXs, or build drag cars (background of pics).
That swap is looking nice. I like the custom mounts, is that polyurethane? I'm in favor of keeping stock twins. Good luck.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Looks like Mckinney mounts to me. Nice looking swap so far, Keeping the Stock twins? or going for bigger and better things.
govtworkhorse
Brilliant! That is exactly what I would do.
lilskyline240
Car: 90 240sx w/ rb30det
what mounts and what transmission you running?
also where did u get the motor from and for how much? cuz that S**T is clean
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
lilskyline240 wrote:what mounts and what transmission you running?
I actually got the motor off of ebay from a kid in california that was going to swap it into his 240 but crashed it and gave up and sold me his R33 rb26 for $2600 plus $400 to ship it to my house. I detailed the motor when i was preping it, I have a progress thread on racebread. and im running an R33 rb25det 5 speed transthat i got for $1100 from JDM engine corp out of texas.heres the link to all my progress: http://forums.racebread.com/index.php?topic=1637.0
DJButton
Car: 2010 Nissan 240sx
Looks like she belongs in there, nice job so far!
Chaos the Xile
Car: 1974 Datsun 260Z
WOW! Very beautiful! I hope to be working on a 26 swap next year congrats! We wanna see more pix and some vids when its all said and done!
lilskyline240
sweet man....great deal on the motorset...you got really lucky
REDLN
Car: 95 Nissan 240SX SE
nice, clean swap you got going there. can't wait to get mine going.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
heres some recent pics from tonite...
madcowvert
very clean great job
Sil240
Car: Nissan S13 "The One Cam Wonder"
NICE!!!Better camera.I was getting worried that you painted it Orange ewwww
002-M-P
Car: Z33-RB26 IP
Looks really good man. Did you tear down that block at all to check it out before installing it?
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
002-M-P wrote:Looks really good man. Did you tear down that block at all to check it out before installing it?
i checked the crank collar and put new water pump, timing belt, tensioner and idler pulleys and new intake gaskets and etc. you can check out my progress on my racebread.com thread thats in the upper posts and check all that i did if you like
minivan_don
im still waiting for my mckinney mounts to arrive and i havent seen any instructions floating around, but you didnt need any parts like the ka trany/engine mounts (or other) to install your mckinney kit did you?
im a bit scared myself as it looks like i wont be able to keep my ac if i want to use my fal 210 (pullers) fans
BOOMSHAKALAKA
Very nice! Good job
gawdzilla
Car: none
nice, looks like my old setup
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
minivan_don wrote:im still waiting for my mckinney mounts to arrive and i havent seen any instructions floating around, but you didnt need any parts like the ka trany/engine mounts (or other) to install your mckinney kit did you?
nope the kit came with the motor mounts and transmission mounts so all you need is a s13/s14 and and RB and your fine but you will have a big problem running puller fans cause i have the low fal fans and there was no way in hell they were going to fit and run as pullers. i accidently bought the 220 fal fans and i had to but the pusher fan blade replacements cause i would had to wait 4 weeks to exchange them so i just got the blades from summit for $20 ea.
Modified by HxC_Nismo at 5:58 PM 2/7/2007
BoostFab
Car: S13cp, S13fb, S14z
wow that motor belong there.
minivan_don
no way!!! i wanted to keep my ac at all costs :S
ive thought of a few options:
1) remove the ac condensor and run the pullers on the front side of the rad ... pros - hits the fmic when sitting cons - no direct air movement IN the engine bay.
2)notch out the front crossmember after some reinforcements and see if i can mount the fans the regular way
3) same as option 1 but use pusher fans if that will help... if any ...
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
minivan_don wrote:no way!!! i wanted to keep my ac at all costs :S
well go for it man it sounds like you got it all figured out, this is not my daily driver i have an acura with a/c to drive to work so its not needed for what my plans are for it.
