mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Fri Aug 10, 2007 10:08 am
Not sure how you could move the key, it's jammed in the cam pretty good. My (and lot of other dudes) key broke off a while ago, so it's kind of a pain to reinstall the CAS correctly. Just take your time and you can line it up perfectly...
Anyway... Any time that you remove the CAS without first marking its original position you need to re-time the engine. I'm sure your timing is off unless you carefully marked & reinstalled the CAS. All you need to do is use a timing gun to double check your timing, it takes less time than writing this post/response!
