dana0330 wrote:It is a low knock it is there all the time.......I ran Marvle mystery oil in the engine to try to stop the knocking.....
It's expensive changing oil and filter after only a few miles of driving but you might consider a couple more successive treatments with MMO. I had a similar ticking in my 94Q when I first bought it and it took a BG engine flush and 3 MMO treatments to finally quiet it down. IIRC I drove for 30 minutes after a BG flush and a day after adding MMO before changing the oil and filter.
I hope the knock you're hearing is a HLA "tick" and not a slightly bent rod from a previous owner's hydrolock incident. I'm pretty sure my 94Q died from hydrolocking (leaky injector o-ring) and even though it had a loud knock and the oil light was on the engine idled without shaking and revved as smoothly as if there was nothing wrong.
Pulling ECU codes will tell you a lot about what's wrong.
