DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Sep 13, 2006 4:38 am
this has happened to me twice, just immediately after ive put a motor in.
i had a perfectly running car whne i pulled the motor. but when i would put it back in, like to do a clutch or just a swap, it would run like ***.
sometimes fuel injectors just die randomly, it happed to me twice. check the resistance across the injectors for 11 or 12 ohms.
then check to see the plug wires are in the correct order, that happens all the time too
then make sure the distributor timing is decently on
and if thats still no go, then you gotta check cam timing, and possibly compression unfortunately.
but in all honesty, i think you mihgt have had an injector spontaneously die. it sounds weird, but like i said, it happens.
