Finally got my manifold back from peak boost .
pauliedrft
Car: 91 240sx
i finally got my manifold back .Ceramic coating takes way to long if your in a hurry lol I hoping to have it running this week end .Please pray to the sr gods for me and wish me luck.(no more grimlins )chug:chug:chug:
S14toRPS13
It looks sexy! What type of numbers are you expecting to pull from your set up?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
MastaYu
Car: 92 Nissan 240SX SE HB
nice!
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
How are you venting the wastegate?
xX RB Xx
Car: SE3P, FC3S, FC3C.
sexy
pauliedrft
Car: 91 240sx
How does it look vented to you .lolMy numbers well running stock maf and injectors , 250 or what ever it will let me have . With my fuels upgrade , ( 550 cc injectors aeromotive fpr raising rate , z32 maf and a tune or stand alone). The limit would be around 350 to the wheels I may go to 800 cc so i can run e85 180 a gallon for 115 equivalent. Of course i would need some cams i will dyno it as soon as i have her broke in and the bugs worked out .
jr_ss
Car: 95' S14
You need bigger injectors than 550's, you'll max them in no time and it'll be a waste of a turbo that big. Even if you ran 800cc's you'd still need bigger injector's to run E85 and get the most out of the turbo. I suggest running Sard 850cc's on regular pump gas/race fuel. If you want to run E85, you need to look into running top feed injectors and going to 1000cc's or higher. Not to mention SS teflon fuel lines, as E85 will melt regular rubber lines.
24j0hn
Car: 91' 240sx with some babying to be given
love the natural silver look
pauliedrft
Car: 91 240sx
Dude can we say budget . im going to go 800cc 740 netted a guy 398 to the wheels so that is plenty for me ,until i build the bottom end ,v8slr is his screen name .And have you watched your duty cycl on your set up to know that they wont let you wield 350 to the wheels???
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
Great looking engine man. I like the new mani, looks tight. Polished cover ftw also.
Open dump pipe is what I'm assuming, yum!
Also where did you get your blue valve cover nut washers? Or did you just paint em?
DustyS13
Car: 1992 s13 Coupe
I love the silver look
pauliedrft
Car: 91 240sx
Grinder with wire wheel , (scar on right hand seriously ) extreme paint from walmart blue anodized 3 coats and then 2-3 coats of clear . Which is what everything blue on my car is done with .Thanks for the comments Ive been working on this motor since February .
jr_ss
Car: 95' S14
Ok, but I'm telling you that 800cc injectors aren't going to give you enough head room to run E85. You need 30-40% bigger injectors to run that stuff, and 800cc's just isn't going to cut it, unless you plan on running strictly 93 or race fuel. That's all I'm saying.
