smocan »
https://forums.nicoclub.com/smocan-u33734.html
Wed Apr 16, 2008 2:54 pm
Umm no one is saying ebay is the problem, its the horrible crap like the slip over coilovers you buy on there. Your not anywhere near the first one testing them, so save your 20 bucks. I will explain the best I can so most can understand, even though alot of your will be like, uhhhhhhhhhhhhhh ebay is KEeWL, which you should keep your mouth shut because your an idiot.
The slip over coilovers, like the ones you get are ****. As you can tell, theres not even a manufacturer name. All of the springs are made and thrown into a pile, 4 random springs are picked, which all have different spring rates... but if your following, the factory that makes them could care less. The Adjusters furthermore are complete junk like the springs, which will corrode and strip and jam and break and end up being useless, well as a whole, thats what they are anyway.
Ground Control on the other hand, uses quality adjusters and brand name springs which are all properly grouped together with the proper spring rates, or can be custom ordered to your desire. They will also can help you out to find what your looking for if you call them up. These also are made to work with a specific shock your using. Although many of you think buying KYBs and grouping them with these is fine and it is, but thats not what all the rave is about. The best setup is properly calculated with the proper string rates and valving. Research is needed to understand what setup your looking for and what proper specs on the springs and struts so they work together like a true coilover system should, not like all the crap everyone on here buys, including me. The best results are found with upper level konis matched with these ground controls, which are matched with and for eachother. This can provide a comfortable ride with good stiffness on the weekend, or possibly a great stiff suspension setup for the track only.
Do your research and these will outperform almost everything out there.
Ebay is complete crap for the most part, except stuff that isn't dangerous or can cause a crash and exhausts and such which your life doesn't depend on, but still most is junk... unless you buy brand name stuff, which even I do when I see a good deal.
OP good luck wasting all your money by doing everything wrong the first time.
