finally got it running but......
J2fast
Car: 240sx
so ive been working on my rb build for about a year now and had a few motors in this 240sx. i first got it running back in Jan for bout 3 wks but the transmission broke so sourcing parts and research took awhile so i just bought one. then while the car was down i desided to put another turbo in it. i went from a 50 trim which i made 520 whp to a turbonetics T72 turbo which i have right set to 15psi (dont know the exact hp) i had 880 injectors and replaced with 1000's (im on e85) the other motor had a lil bit of a porting job when i got the motor, head gasket, greddy timing belt, head studs, r34 rb25 n/a short block. now that motor was ok on power(at the time i thought was really good) it was a lil bit sluggish in the off boost parts. well after i had put the new turbo and injectors on that motor i had took it out and not knowing one of my fuel pumps failed and BAM there goes cyc #6. so i got a new motor completely stock in put it in there with the same aftermarket parts with the same tune and this motor rocks hard. so far on my tune im getting that turbo to be at full spool on 15 psi at 4800 rpms an redline to 7k( will raise when i change the belt, its loose). idk the power but it fells ALOT better than the other setup by far i dont much pic of the car but ill show you the work over time and what happened to it after the last motor blew, it caught on fire. i will post new pic of my new setup prob tonight
this is at the car show in Jan old setup
this is when we got it working the first time
this is what happens when cyc #6 has no compression and alot of blow-by
J2fast
Car: 240sx
no one has any comments on what they think about the car????
julio
Car: RB26 AWD converted S14
J2fast wrote:no one has any comments on what they think about the car????
I like the chicks. What are you hoping to make with the E85+T72? Sounds like a pretty crazy setup for a stock short block.
yotik
Car: 240sx Hatch
nice looking gir- i mean car!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
gonna get a new block? whats your next step?
Joe
how does a bad cylinder make a car catch on fire?
J2fast
Car: 240sx
I'm hoping to make about 500-550 whp. I build the setup for highway runs mostly but I may switch turbo later due to the bad lag
J2fast
Car: 240sx
USMCgetsome wrote:gonna get a new block? whats your next step?
I have rb26 internals at the house which I plan on using mid next year
J2fast
Car: 240sx
Joe wrote:how does a bad cylinder make a car catch on fire?
It had a lot of blow-by an the oil caught on fire when it jumped to the turbo
Joe
blowby usually doesnt throw oil out of the engine...
flatrate
Car: S14 kouki
Joe wrote:blowby usually doesnt throw oil out of the engine...
it certinaly can, if he didnt have a catch can setup or just had the breathers open
J2fast
Car: 240sx
I have n had a catch can setup but cyc 6 had no compression at all. It even blew the catch can hose off first and then the dip stick which is where the oil came from to start the fire
Joe
there we go, well that sucks man. hope you can get it fixed
and anyone that runs open breathers on a turbo engine deserves to have their car to catch on fire, thats just STUPID.
J2fast
Car: 240sx
Joe wrote:there we go, well that sucks man. hope you can get it fixed
Yeap it does but oh well. I've got my new motor in and trying to mess around with the tune a lil bit but I think I need a small ar on my exhaust housing cuz it's taking to long to spool up
