notslow »
https://forums.nicoclub.com/notslow-u48608.html
Sat Jun 21, 2008 2:21 pm
do you plan to do the swap yourself? First search the forums, you will find tons of info. The harness can be a bit of a pain. Besides that check your motor mounts to see if they need replacement. Also check the clutch, see if it needs replacement. Throw on any mods/clean the engine bay etc before you swap in the engine and that way you wont hate life. You also need to look at your horsepower goals and figure out a game plan based on those numbers.
If you need anything you cant find from searching we are always here to help.
