Finally got 13's but not without problems...
Turboed240
Well, I finally got the car into the 13's this weekend with a 13.6 at 99.6mph runnin on 11psi. It did it 3 times then, after the 3rd run, I heard a ticking coming from the motor. It sounds like either a bad bearing or a bad valve. It's a tapping noise that only appears above 2500rpm. Kinda crazy though if it ends up being a valve cause I rebuilt the head with Greddy valve springs, rocker stoppers, etc...Oh well...any ideas on what else could be my problem. Car doesnt seem to stumble at all. We took the valve cover off and we didnt see a busted rocker.
lok
My friends civic had the same problem after being ran hard. But it turned out he was low on oil and it spun a rod bearing. We tried replacing it with the thickest bearing available but had no luck and had to replace his motor. It also would only make the noise when you reved up past 2500, but then it eventually turned into an all the time ticking. Good luck on whatever it turns out to be.
Turboed240
Now dont flame me for this one but this is one thing I dont know...does the SR have lash adjusters like the 4g63 motor? I was wondering if it could be a bad lash adjuster...
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
wish i could help ya but i have no idea what you just said. you can always get a buddy to rev the car while you stick your head under the hood and try to listen for where the ticking is coming from, that should get you a better idea of whats wrong.
-tim
Turboed240
Well, we did that...we took the valve cover off...started the car (Yeah, I know that's bad) and listened real carefully. After taking an oil bath, we couldn't hear where it was other than it was in the top end somewhere. So confused.
Turboed240
Okay, so we did a compression test and every cylinder came back 100psi. Anyone know what typical SR compression reads?
S13240
That motor is bad. Compression should be above 128 psi minimum. 150-155 is maximum/good compression.
Turboed240
Is that even with 1.2mm headgasket? Kinda hard to believe that the motor would be bad being that every cylinder read the exact same thing and that the motor still ran okay even with the knocking.
S13240
That's compression on stock motor.
Turboed240
I'm starting to think that my problem may be oil depravation to the lifters...I'm gonna check my oil pan tonite to see if there are any dents.
