jdm_master_X »
https://forums.nicoclub.com/jdm-master-x-u30964.html
Tue Jan 02, 2007 5:03 pm
So I am finally going to do the 5 lug swap after learning my wheel bearings all ball joints all took a dump.
-getting the s14 front spindles for $60. what else should i get? this is a flat rate price, so i can get more. the 4 hubs are already gone
-i can get MOOG balljoints at wholesale price.
-hopefully, my rear 5 lugs will be arriving soon....
-getting jeep cherokee meshies for $60
-already got the q45 brakes! so lets see...questions questions...
1. will my stock sized 15s from the SE wheels fit the cherokee meshes? the tires on the meshies are 235/75/R15 while the SE wheels are rockin 195/65/R15.
2. am i missing anything as far as front suspension from the S14??
3. does anybody know exactly how much the strut bolt holes need to be enlarged? maybe i can go to a metal warehouse and get some steel piping to act as sleeves so i dont have to drill into the strut.
4. where could i find S14 front hubs on the cheap? part number 40200-0V010 is what im looking for. does it matter if its an ABS or Non-ABS hub? above number is an ABS hub. Nissan has 13 different part numbers...eesh.
anyway, suggestions are welcome. thanks brothers!
Modified by jdm_master_X at 7:26 PM 1/2/2007
