Finally Dynoed....New Problem
240sxOwner
Car: 93 240sx
Finally got the 240 dynoed after a year of "how much is that thing puttin to the ground?" I only got one run, because i had a surge of coolant burst out of the radiator cap right after the run. This is just barely hitting 10 psi
Max Power - 285 hpMax Torque - 267 tq
T4 turbo with V-trim compressor wheel. JE pistons, FMIC, Revhard Manifold, 3 in Exhaust, ARP head studs. 150,150,150,130 compression.
Anyone else have an idea as to why my coolant did this? Driving normally out of boost the car will run forever w/o overheating. I will post the dyno chart as soon as i can.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
240sxOwner wrote:Finally got the 240 dynoed after a year of "how much is that thing puttin to the ground?" I only got one run, because i had a surge of coolant burst out of the radiator cap right after the run. This is just barely hitting 10 psi
Head gasket? Compression leaking out in the cooling system can cause that.
C-Kwik
^^^ Sounds like this could be it. I'd do a leakdown test to confirm.
Swedish Mike
C-Kwik wrote:^^^ Sounds like this could be it. I'd do a leakdown test to confirm.
The hard part is that they sometimes only leak at max boost (for a start). Hard to test.
240sxOwner
Car: 93 240sx
im afraid it is...that is what my original thought was..
KATwo40
Car: 1993 240sx KA-T
Cometic headgasket?
240sxOwner
Car: 93 240sx
fel-pro....cometic to come...
any sponsors have a good deal on them?
eazye2000
Car: S13 KA-DET
240sxOwner wrote:fel-pro....cometic to come...
How is $69.20 sounding to you?
http://www.amsperformance.com/...d=153
Florida240sx
What did you torque the arp head studs to?
240sxOwner
Car: 93 240sx
I torqued them down to the max amount the specs say to for the stock bolts...That is what i was told to do by someone else on here.
boznuttz
Car: MS13
Did you follow the fsm while tourqing? Also, a few days ago my friends removed the head of his 89 sohc and......the coolant galleries and passages were completely clogged.
nissanfanatic
Car: 1992 Nissan 240sx SE
Your problem isn't HG strength.. There is another problem with your setup.
fiznat
Car: Grown up :(
Think simple first. Your coolant will shoot out if the cap wasnt screwed on tight enough. Is it possible you didnt put it on right, or maybe it got bumped? If this has never happened before and it is not happening anymore, I would really look for the cheap/easy fixes first. 9 times out of 10 the solution is something really stupid.
Also if you go with a cometic MLS headgasket, I would also consider resurfacing the block (decking) and the head. MLS headgaskets dont conform as much to the surface of the block and generally requre a VERY flat surface in order to seal correctly.
WDRacing
Word ^^ Copper FTW
240sxOwner
Car: 93 240sx
i thought it was a cap problem...so i tried 4 different ones and they all do the same. This only started happening after i blew and intercoolr pipe at 12psi one night. Later down the road i will be rebuilding the motor completely...should i just get another fel-pro for now?
I guess the numbers are pretty average or else i would have gotten a comment on them...lol Thanks for the help, keep it coming
masterteque
Car: 1993 s13 convertible 1993 s13 coupe
Sounds like a blown head gasket......
fiznat
Car: Grown up :(
Do you have a way of continuously monitoring your coolant temperatures? ...I mean, something other than the dummy gauge in the cluster. If you have a blown HG you will see the temperature shoot right up very quickly as you get into boost.
If it is still happening, blown HG is probably the most likely reason. Do you have coolant in your oil, or oil in your coolant? Is your car smoking at all? Coolant will burn white and the smoke has a sweetish smell to it.
240sxOwner
Car: 93 240sx
no mixing of fluids......no smoke....car runs like at absolute champ.
My other temp gauge just broke so dummy is all i have at the moment
KATwo40
If you know of a shop with a 5 gas analyzer (should be pretty much any shop that does vehicle inspections in your state), you can figure this out pretty easily.
Stick a hose over the radiator neck (radiator cap off), about 2ft long, pointing straight up. Run the car, stick the sniffer down in the hose and see if you get:
HydrocarbonsCO2CO
That'll tell ya' pretty quickly.
I'm bettin' you have a leaking headgasket, given that odd cylinder compression number. I'd just get another Fel-Pro gasket.
TheOne
Car: 93 240sx FB
compression numbers aren't right, JE pistons ~8.8-8.5 compression ratio?(wondering due to rather lower compression numbers, those seem fine cept for #4)
also there isn't supposed to be more than 14psi difference between pistons as far as compression goes, sounds like you are shottin boost out of piston 4, and its goin into the coolant passage.
also don't you have to re-torque arp studs after so many miles?
240sxOwner
Car: 93 240sx
if you are supposed to retorque, i wasn't notified..lol The 4th cylinder has been at 130 for 8 months of track use and beating up on it and i never had this problem until i blew the intercooler pipe.
After a normal drive when the car heats up, you can hear the hissing from the radiator cap, but every cap i have tried does the same thing. Is the coolant system getting pressurized some other way? Is it possible?
nissanfanatic
probably a really good sized consistent headgakset leak...
TheOne
Car: 93 240sx FB
240sxOwner wrote:After a normal drive when the car heats up, you can hear the hissing from the radiator cap, but every cap i have tried does the same thing. Is the coolant system getting pressurized some other way? Is it possible?
too much boost could try to escape to weak spots on the headgasket and goin into the coolant, tho the hissin is prolly the overheated water/coolant turnin into gas & maybe pressurizing the system.
i was told about the retorquring on V8's(friend has an lt1, has arp head studs and he's supposed to retorque'em after a warmup/cool down on the first start or so), probably the same for the ka as they used the same material and what not.
WDRacing
I posted this in another thread about ARP hardware. Always retorque or torque check things like the head and what not. If its accessable, then check it. Everything stretches, so a retorque is almost always done on my cars.
Ive been a helicopter crew chief for 13 years. We retorque or torque check everything.
If I were you, I'd retorque the head right now. Just to see what happens. Worst case scenerio, nothing changes. It only takes about an hour of time.
